platbr's avatar
platbr
Camp Lite Livin' Lite question -- new fiberglass sides
We are looking at Camplite Livin' Lite trailers, and have liked the fact that they are all aluminum construction, including the outer skin. Tonight, I noticed that one of the 2018 Camplite 21BHS models I found had "new with Fiberglass sides!!" The window sticker lists "PROTO: GREY FIBERGLASS EXTERIOR."
So does anyone know a reason for the change? Prior years were aluminum skin over Azdel. Any concerns buying "last year's model" with aluminum skin?
  • We had to have our TC door replaced due to the corrosion. Door was made by challenger and it was replaced under warranty.
  • djsamuel wrote:
    platbr wrote:
    djsamuel wrote:
    They are building the fiberglass side units as prototypes for a possible sub model. Not sure of the rationale behind it, but they continue to manufacture the aluminum sided trailers with no announced plans to switch to fiberglass only. I think they are looking to come out with a lower cost line that still has the benefits of no/minimal wood, without discontinuing the current line of aluminum sided models.
    Thanks. Here was an official response I got today: "Thank you for your inquiry. Livin Lite is adding the option of having Fbg. Exterior to their units. You can still get the trailers with the Aluminum skin, but there is an option now for the fbg."
    I'd wondered if there was some underlying issue. We had some nasty filiform corrosion issues with our Airstream Bambi 19, and I didn't want to wade back into those problems if there was some issue nobody was talking about. But it sounds like the aluminum is still the preferred option.
    My Camplite 21BHS is about 4 years old. I have no filiform corrosion on the camper sides/frames at all. The only place I have anything like that is a small area on a cargo bay door near the latch, and another small area near the bottom of the entrance door. The doors are made by Challenger. The spots are very minor. The camper itself is free from any such corrosion.
    Never heard of filiform corrosion before so I googled it. Learned something new already this morning. Informative forum.
  • They are building the fiberglass side units as prototypes for a possible sub model. Not sure of the rationale behind it, but they continue to manufacture the aluminum sided trailers with no announced plans to switch to fiberglass only. I think they are looking to come out with a lower cost line that still has the benefits of no/minimal wood, without discontinuing the current line of aluminum sided models.
  • Cost ? Mfg.'s tend to make them as inexpensive as they can. If they can find a way to make a dollar on every unit they sell, that's what they do. The rv industry is becoming cheaper and cheaper and we keep buying and buying. Who's the blame ?
    One day soon, umbrella's and rain poncho's will come as standard equipment to be used inside the rv.
  • Probably it's Thor starting to cheapen the manufacturing. That's just a guess, but based on everything else going on in the industry it's an educated guess.
