popeyemth wrote:
1)you must raise the axle and turn the wheel WHILE you add grease
2)expect to add about a tube per wheel the first time as the hubs are not filled at the factory
Good Luck, Mike
X2
5 shots ain't going to get it.
I'm from the old school in doing it manually. A couple of years ago I had to leave with the RV suddenly in the spring. Well I decided to just use the easy lube for the first time in my life. Followed the instructions and was concerned about the amount of grease they needed.
Ol well had to leave and got back home fine. Pulled them off after returning and everything looked great. I still do em manually but not every year now as in the past, depending on mileage.
The bad response to these are most folk's don't follow instructions IMO.
