ticki2
Dec 06, 2021Explorer
theoldwizard1 wrote:CA Traveler wrote:
Buy a test light or voltmeter and check the charge line at the plug. Once it is charging you may need to use larger wire for faster charging.
You need to test the voltage AT THE HOUSE BATTERY after the engine has been running for 5-10 minutes. You will be surprised how low t s.
Low voltage is one thing , no voltage is a different problem
44,071 PostsLatest Activity: Aug 16, 2026
