covered_wagon
Dec 07, 2021Explorer
desertratt1 wrote:
I thank everyone for all the impute. Looks like i need to do some checking. I looked under the hood pulled the fuse/relay cover i have a trailer relay. Not sure how all that works. Camper is off truck i will hook it up start checking things out. I just assumed the truck would charge the battery period. My Dodge is a camper special. I plan on installing a 200 watt solar setup at some point but i considered the truck charging the battery in the camper a given. Like i said will look at all the suggestions to resolve this over weekend. Than will get back and post.
Thanks
Rick
My 02 is a camper special as well. I have my continious duty relay switched so I can let the alternater replenish the starting batts from using the starter, grid heaters and finally seat heaters. Once warmed up and time allowed to charge the truck batts, I switch that on to take care of the two camper batteries. 5 hrs run time brings it up to near full charge on 2 deep cycle 12 volt batts. It works great and run furnace whenever I need, sometimes all night.
That was a good suggestion to make sure your fridge is not set to run 12 volts. I never use the automated setting.
