jimh406
May 26, 2015Explorer III
I think it is likely that you can scrape the double sided off the rubber, or use some light heat with a hair dryer. Then, use some good adhesive remover and clean with alcohol. Follow that up with good double sided 3m tape or similar from an auto parts store. I'd put masking tape to mark where it should go before applying the rubber.
44,068 PostsLatest Activity: Jun 01, 2026
