AnEv942
Jul 06, 2020Nomad
wnjj wrote:
Look again. You can see half of the exposed bolt holes running left to right. The entire front half of the stud is gone, split right across the bolt line. There are also bolt holes going in (looking straight into the photo)...
I see where front lag bolts pulled out of face and face of wood split off where side lag bolts went thru but I also dont see where there were thru bolts. Looks similar to our rear jack mounts-no thru bolts just lags.
Which Id look at replacing mounts that also had thru bolts, though don't know what jacks you have. Just give more mounting surface if you can get to back side of front wall corner.
