Now if you're more pracitcal in your acceptance of capacities and willing to do some additions or simple modifications to your camper hauler, based on component capacities and leaving overall truck class gvw ratings out of the equation (it's a fact that some/a lot of gvw ratings are limited by the class rating of the truck and not its real capability or even the lowest rated component in the system), my general rule of thumb for newer, last 10 years give or take, models is this.
To stay within the component ratings with the exception of spring rate or ride height/stability preference, 4000lbs is a rough limit for 2500/3500 srw model trucks. Add a little for a long bed, subtract a little for a shortbed potentially depending on the campers cg front to back.
Unless overloaded on spring rate, a hefty rear stabilizer bar and devices to engage the overload springs without a lot of sag are IMO almost unilaterally a good choice. Additional weight carrying mods after that, up to wheel or axle capacity.
3500 dually, take that up to 5000-5500 lbs.
Any more than that, start thinking hard about a class 4 or 5 truck.
