larrybluhm
Mar 14, 2019Explorer II
You might consider a window boot to (mostly) eliminate the issue. Most manufacturers offer one as an accessory and they aren't necessarily make/model specific. The removable pass-through window on my Northstar Laredo did well with water before I "got the boot" but blew out a couple of times if the latch wasn't very carefully closed. The pass-through is mostly kept open since the boot and heat/AC will pass back to the camper while on the road. I can also wiggle through if sufficiently motivated...
