SoCalDesertRid1
Jul 03, 2016Explorer II
Tires, wheels, springs, shocks, sway bars and rubber suspension bushings can all be upgraded, to help the truck better carry the weight, in an overloaded situation. I have done all of these on a few of my trucks.
There is very little that can be done with the brakes to make them work significantly better. Drilled/vented rotors can help them not fade as much during repeated braking. Different pads/shoes can be used too, for a small improvement in braking, or for longer wearing. However, none of this does much to truly significantly help braking ability.
Aside from swapping in another axle from a bigger truck, with bigger brakes on it, you're stuck with whatever the truck was made with. And therein lies the main problem with running a truck overloaded: Poor braking ability.
This is a major reason why I decided I was done with driving overloaded F350's and got a truck with significantly bigger brakes (after one of my F350's was destroyed in a fire). I got a class 7 commercial truck, and loaded it to significantly less than it's 33,000 GVWR, while also quite a bit heavier than F350 could ever hope to carry. It weighs 20,000 lbs and stops on a dime. :)
