rbpru
Feb 21, 2014Explorer II
I can tell you from experience there is a big difference between being able to tow and proper towing.
My 2002 F150 was rated to 6000 lbs. so a 4500 lb. trailer should have been piece of cake; but as has been noted, a loaded trailer gains a lot of weight. More important, the 200 hp. motor and transmission were not able to pull the load. 50 to 55 mph was the best I could do on even a small hill.
Matching the truck to the anticipated load and understanding the numerous weight details make towing much easier. So in answer to your question, can you pull it, probably yes; can you pull it well, probably not.
44,072 PostsLatest Activity: Aug 23, 2026
