ArnExplorerSep 17, 2021Can I Use Gear Oil On Dual CamCan I use an 80W90 gear oil to lubricate the trunnion pivot points & cams on Reese Dual Cam? Reese says grease on cams is okay if close to 1200lbs hitch weight. I'm about 1,150lbs. Thanks.
Related Contentlanding gear dual motorsPower gear electric leveler motor/gear ass'yDual Motor Landing Geardual alternatorsF150 3.31 gears vs 3.55 gears
