Can I use an 80W90 gear oil to lubricate the trunnion pivot points & cams on Reese Dual Cam? Reese says grease on cams is okay if close to 1200lbs hitch weight. I'm about 1,150lbs. Thanks.
I currently use wheel bearing grease on ball & trunnions as well. I tried Reese's recommendation of Vaseline on the cams without much success. Sometimes when turning the friction is so great that it sounds like something is breaking & the "pops" are so violent they seem to shake the trailer. Next up, white lithium grease. Thanks.
