ArnExplorerSep 17, 2021Can I Use Gear Oil On Dual CamCan I use an 80W90 gear oil to lubricate the trunnion pivot points & cams on Reese Dual Cam? Reese says grease on cams is okay if close to 1200lbs hitch weight. I'm about 1,150lbs. Thanks.
notevenExplorer IIISep 18, 2021As mentioned gear lube is very pungent...A plastic squeeze tube of the waterproofest grease you can find would be a reasonable choice.
Related Contentlanding gear dual motorsPower gear electric leveler motor/gear ass'yDual Motor Landing Geardual alternatorsF150 3.31 gears vs 3.55 gears
