Likely you'd have to go to an LED (if you can find one to derectly replace with higher lumens output} VS the incandescent OEM bulb. A brighter Incandescent bulb would put out more to a lot more heat than the OEM original.
For instance: An OEM 1156 incandescent bulb will draw 30+ amps of 12V DC and get very hot, way too hot to touch, while an LED with the same lumen output will only draw about 5 amps and is only warm to the touch. The excessive heat produced inside by a higher lumen output bulb in the enclosure is your eenemy! Heat produces no lumens (lost energy consumption), but sure can produce a fire or the melting of the plastic enclosure. Not good!
The cargo light bulb like most other vehicle bulbs are usually trapped inside a small enclosure and a higher heat output could mean a fire or at a min a very short use life before bulb failure. Burn out so much quicker. Especially in hotter climates or in a hot summer elsewhere. Lumens is the measure of light output.
LED's even at double or triple the lumen output are so much cooler operating when on. Just a fraction of the heat produced by a same lumen output incandescent bulb and also last 10+ times as long before failure.
If you are handy and able, it's possible to install a different socket inside the cargo light enclosure so a 12V required LED with a much higher lumen output could be used. I had done this myself in2 of our 5th wheel basements and more than doubled the lumens.
