rockhillmanor
Jan 25, 2014Explorer II
gemsworld wrote:
Out of curiosity, how are cassette toilets cleaned? Do you use chemicals to keep the odor under control?
the Thetford porta-pottie toilet size and looks EXACTLY like the one in the RV's. There is a sealed cassette under neath the bowl.
You can buy 'different size holding tank capacities'. It detaches and you can take it to a public restroom while traveling or a dump station. Has a sealed arm that opens and comes out for pouring it out. Zip zero smell. You use same chems as RV holding tanks.
I use one when traveling from up North to the South because the MH is winterized and I do NOT do public restrooms. I placed it right next to my MH toilet. I dumped it at the CG dump stations.
http://www.thetford.com/HOME/ApplicationHome/RecreationalApplication/tabid/85/Default.aspx
And if you are REAL lazy and don't want to push a lever to flush, they even offer one that has an 'electric' flush!!!! :B
