peoples1234
Apr 10, 2017Explorer
Okay, and just to be clear. When you say 9 links, are you counting from the end? I was confused by your reference of 7 or 8 links being better.
With the Blue OX, you should be counting from the bitter end up 9 as a starting point (counting toward the bar).
At 9 links, there should be about 3 links visible from the shackle to the bar. Adding links to tighten the bars is perfectly fine as needed to level the trailer.
