Help with purchasing - Truck + Camper that can still tow
Hello,
I am looking at purchasing a truck + camper for use at the race track, but I will still also need to tow the car out there. I found a truck + camper locally, but I'm not sure on how much GVWR will be left for towing, passengers, gear, etc. I'll include the details below.
My concern is that I'll need to tow a 16ft flatbed and race car (currently a small car, but could be a bit larger in the future) Tongue weight probably in the 500-600 lb range .
What I can't figure out is how much the camper will weigh ready to camp. Even the dry numbers I've found are pretty different depending on where you look .
Anyone have an idea of whether this is going to be a feasible plan or not ? The truck/camper are not too far, but still a 90 minute drive each way, or so, so I'd like to have a good idea before I go look at it .
I appreciate any input , as I'm a bit out of my depth here .
Truck: 2005 Ford F350 Super Duty Crew Cab · XLT Pickup 4D 8 ft (GVWR verified 11500)
https://www.facebook.com/share/17ebc8Yo9e/
"2005 F-350 XLT floor shift 4x4 with manual hubs. NO CANOPY WITH IT. Has a lot of work done to it. Just put a brand new set of Toyo ATs on it (29570R18). Have the paper work for when the head gaskets, head studs, EGR delete and all that was done. Has the blue spring kit installed, new rancho shocks all around, happijac camper tie downs, 2 new alternators, new batteries, custom seat covers, New thermostat, water pump and heater core not to long ago. Suspension is in great shape. Has had the oil changed every 5,000 miles and fuel filters every 10,000. Has been an awesome truck, towing, commuting and everything. No major break downs or issues in the 6 years I have had it. Air bags in the rear. Will sell truck and camper as a package."
Camper: 1998 Fleetwood Caribou 11J
https://www.facebook.com/share/1Dwaaf2N17/
" Everything works, other than the fridge on electric. It’s clean and well taken care of for its age. It’s a big camper so will need a 1 ton with air bags. Electric jacks, slider front window, 40 gal fresh water tank, AC unit does AC and heat off electricity, no leaks inside or out.will sell truck wil as a packaged deal. "
