lawrosa
Apr 10, 2017Explorer
What ever you do at the scales your goal is to get the front end back to the original ride height/weight as mentioned..
example.. If you weigh the truck only and your front is say 3500 lbs. That is what you want to read with the WD bars linked up. Or as close as you can get without going over.. Never go over...
The other issue is what size spring bars you have? And is set up correct on the WD?
Once we get your #'s we will know more..
Whatch this video on blue ox.. Also wheel well mesurements can get you close before going to the scales possibly..
Blue ox..
Blue ox..
