rbpru
Apr 10, 2017Explorer II
When I left the dealer, he mentioned that I would have to find the link that worked with the loaded TT. It took two more links for a level TT.
The WD hitch directions say to adjust for a level ride.
Also remember that the weight of your rig is going to very with the water, gray and black tank levels, food and other consumables, gas tank levels, propane level and the stuff hauled on each outing. You will find a couple of hundred pounds is about as close as you can estimate between trips.
