MikeJulieGDImag
Apr 17, 2017Explorer
lawrosa wrote:It was more solid, didn't feel as bumpy when we hit any uneven spots in the road and when we got hit by wind instead of feeling squirmy and getting pushed I could feel the Expedition hold steady and the trailer almost 'snap back' in line. Thanks the info on needing to go back and get re-weighed with the different setups. wrote:
Next important step is to air up your tires to max inflation listed on the side wall.
Can you post what that max psi is and the lbs rating on the tire sidewall?
You are at your rear axle limits and that trucks capacity.
Max tire pressure is 44PSI which I already air up to when I'm hitched up and the lb rating is 2601. 'E' rated tires are coming in the near future.
