MikeJulieGDImag
Apr 17, 2017Explorer
JIMNLIN wrote:op wrote:
Max tire pressure is 44PSI which I already air up to when I'm hitched up and the lb rating is 2601. 'E' rated tires are coming in the near future.
Guess I missed your tires load rating in my reply above but divide the 2601 lb number by 1.1 = 2365 lb capacity for your P tires. A load D or E will stiffen the tire and eliminate that problem...if it was one.
Since this is my first experience with towing I don't have anything to compare it with to know whether or not having 'P' tires is creating a problem. Since I've read so much about the positives of having 'D' or 'E' tires when towing I figure I will put a set on in the near future.
