lawrosa
Apr 17, 2017Explorer
Since this is my first experience with towing I don't have anything to compare it with to know whether or not having 'P' tires is creating a problem. Since I've read so much about the positives of having 'D' or 'E' tires when towing I figure I will put a set on in the near future.
Yes you should upgrade the tires to an LT with that much weigh on them.
But watch out if you go to a higher load range as your rims most likely cant handle the higher psi. These tires are usually 80psi max or so.
Do your homework...
