MikeJulieGDImag
Apr 09, 2017Explorer
CAT Scale numbers (still a newbie to towing)
I had my tow vehicle and trailer weighed today on a CAT scale today.
Steer Axle - 3220 lbs
Drive Axle - 4320 lbs
Trailer Axle - 6040 lbs
The UVW of the trailer is 6204 lbs but we do have a couple hundred lbs of stuff in it now. The GAWR for my 2013 Expedition EL are 3700 lbs for the front and 4250 lbs for the rear. Our WDH is a Blue Ox Sway Pro. I know the rear axle on the vehicle is overloaded and I believe out of balance from front to back which is probably why things felt 'off' when I was pulling the camper yesterday and today.
The question I have is am I correct to assume that reducing the amount of chain links on the WDH bars to tighten things up will shift weight off the rear axle of the vehicle to the front and to the trailer?
The dealer installed the hitch and recommended I hook it up at 9 links but I played around with it some and hooked it up at 8 and 7 links and noticed the rear of the expedition definitely came up some.
No pictures at 7 lengths right now but I do know when I had it at 7 the setup looked identical to what they show in the video with the 3 chain links showing.
