bigfootford
Feb 13, 2021Nomad III
TxGearhead wrote:
I've got 2 or 3 grounds bolted to the camper tie down ring on the front drivers side. I assume they would ground through the tiedowns to the truck frame. I am the 2nd owner but I'm pretty sure it came from the factory like that.
That ground is for grounding the camper to earth when the jack foot is touching the ground.
My 2000 BF's main grounding point for the battery negative and AC ground is attached to the propane copper tubing that is located under the bed step, where the converter is.
Jim
