Scott_Central_O
Jun 09, 2018Explorer
Checking for water system leaks in a Northern Lite
I've got a 2018 Northern Lite 9-6 Sportsman.  On a recent trip I noticed the water pump started short cycling every  minute or 2 when no water was running...just a half second chirp.  My first thought was that there was a leak in the fresh water system that was slowly depressurizing the lines when the pump was on.  I checked the compartment below the seat where the pump is located and don't see any signs of moisture either on the pump, visible pipes/valves, or on the wooden basement floor immediately below the pump.  Beyond that, how do I locate a leak on the parts of the system that aren't visible from the bench seat opening?
Thank you,
Scott
Thank you,
Scott
