Dayle1
Nov 01, 2015Explorer II
Can't comment about which axle ratio would be best for your load and driving usage. But the wide track front axle should provide a greater steering wheel cut. Cars and light trucks are normally around 36 degrees while heavy duty rigs are around 54 degrees. The increased angle will make it easier to get in and out of tight situations. But you need to verify that wide track also means greater wheel cut.
44,060 PostsLatest Activity: Mar 26, 2026
