AnEv942
Jun 09, 2014Nomad
No hi jack- just documenting what been done a gazillion times. If our 'aluminum' frame camper was wood Im sure the corner where water was entering, some would be involved in the replacement. Looking at it you can almost trace the water path. going down the rear corner, almost no damage until it got past the al tube then water wicked sideways.
Advertised @16 gal black-24 grey. In last 2 pics you can see the ends of both tanks. They overlap each other at right angles. Lower part of wing is end of plastic box that contains the black tank-its ~10x14x6+' running width of camper behind bumper. The grey is behind white wall, running north/south in basement. Both tanks have protrusions that stick into compartment. Top half is grey tank setting on bump out of black. Odd arrangement. Among other discrepancies the black is much larger than 16 gal. I think I have the 24gal black that was offered on next size camper.
Edit: Correction- I was wrong-the tank across the back is the grey, black is the one on top and behind the wall. From the cabinet door looking in appears the 3" is going to tank in rear but its not. Also looks like the 1 1/2 is dumping in side tank but its not. Theres a notch in back of side tank that allows the 1 1/2" drain from shower to pass, then angles behind it to rear tank. Having cabinet open plus the rear access panel under wing, revealed my mis assumption having always looked at it thru door. Actually kinda nice discovery-as Ive always want to add a rinser to black tank-located where it is (now) would be easy to plumb. Doesnt explain the volume differance though.
