ShinerBock
Oct 25, 2017Explorer
If you are referring to Ford Raptors, it is a requirement per NHTSA Standard 108 since the front and rear of the Raptor is wider than 80 inches. If the rear of the truck is wider than 80 inches like a DRW is then you have to have no less than three red marker lights in the rear. This is why there were red lights on the tail gates of older DRW trucks before they start just adding three red light into the third break light. If the front of the truck is wider than 80 inches like the Raptor is, then you have to have three amber marker lights in the front.
If you see regular Ford trucks doing this then they are probably just doing it to make it look like a Raptor grille.
