New to TCs and researching my first purchase. I've recently read about COG and I have seen it measured in numbers such as .54 etc. does the mean the center of gravity is 4" in front of the rear axle? ...
As far as COG goes, AFAIK any 'rear slide' jumbo camper will likely have its CG a bit south of the rear axle, however for this reason the wise MFG often mounts the fresh tank forward (and with Chalet the batts too), thus the CG will advantageously move forward depending on the quantity of water carried...
