wintersun wrote:
My camper had a dry weight of over 2700 lbs. when it left Lance. The AC added later put on 100 lbs. at the front third of the camper. Full LPG tanks would add 40 lbs. in total at the front third of the camper. I added a 100 lbs. with a second battery and its frame at the rear of the camper though having the generator option would have added as much or more. A full water tank sits in the middle of the camper and if full would add 240 lbs.
Any way you look at it the addition of accessories is going to be less than 10% of the camper's weight so it does not matter where it is placed. The manufacturers all design the camper so the COG is centered as much as possible over the rear axle of the truck. They do this by shifting the location of the appliances and holding tanks and storage areas as needed.
It is not something that anyone buying a camper needs to worry about if they put a camper built for a shortbed truck on a short bed truck and a camper built for a long bed truck on a long bed truck. The only time to be concerned is when the camper is off the truck as it is front heavy with the cabover section.
In my view, your experienced based comments seem far more applicable with your short bed SRW truck having a relatively lightweight camper, but with regards to OP's eventual rig, a likely super-sized camper (say an 11'-6" double or triple slide), the impact of CG cannot be over looked...
While it is true that Mfg's often attempt (as a logical practice) to try and optimize COG's, ultimately its the marketplace (which floor plan is it that sells...) that governs execution. A few rear bath campers (of any length) even have their grey tanks carelessly located beneath the bath. With a lengthy camper, the extra cantilevered weight of a rear slide-out, two 30# LPG bottles, batteries and generator makes this matter more serious.
To compensate for CG, the MFG of a well engineered jumbo camper will endeavor to place the tanks (and sometimes batteries) as far forward in the basement as possible.
One example is the Chalet DS116, where one will find the battery bank and fresh tank well forward within the basement with the grey and black closely alongside...(Note, the same tank placement is true for the Eagle Cap 995, 1160 & 1165).
In the case of Chalets 66 gal, and EC's (1160 series) 75 gal water capacity, this would mean a whopping 549lbs & 625lbs applied forward of axle respectively.
Its interesting here to note that with Chalets batts forward design, a dead battery means the slide-out won't work nor will the jacks. Chalet wisely planned for this possibility by extending a set of jumper terminals to the campers rear.
In my case (EC 995) we dry camp almost exclusively, and its not uncommon to haul nearly 60gals of water. A bonus of forward tank layout is that the weight of a full tank (500lbs) is nearly imperceptible. This would not be the case with a center or rear mounted tank.
Best Regards,
3 tons
