mobeewan
Jul 22, 2017Explorer
Prior Pete wrote:
New grill works fine with 1 lb tank but no gas is getting through with 20lb cylinder & adapter hose. I know I have propane & I know the hose is okay cuz it works with my other grill. Is it just me or does anyone else have the same issue with this grill?
Coleman appliances usually have thier own regulators. If you are using 1 lb cylinders yours has the built in regulator. If your hose has a regulator on it for the 20 lb cylinder, youu will need a hose with acme or pol fitting on one end and the straight threaded Coleman type connector on the other end and no regulator.
I have never had any problem using Coleman appliances with a 30 lb, 20 lb, 11 lb or even 6 lb refillable cylinders using the proper unregulated hose and adapters.
Propane tee
Propane y connector
Coleman hose
Acme x Coleman hose
44,071 PostsLatest Activity: Aug 30, 2026
