indybp57
Feb 24, 2014Explorer
Jayco25E wrote:Chuck_S wrote:
Ground clearance on the Jaycos has always been a problem not noted on the Roos.
-- Chuck
Ground clearance is not an issue on Jayco's. Yes some set lower than others. I prefer the lower ground clearance. One is it makes it easier for my dogs to get in and out. Second it has less wind resistance going down the road. So do not listen to all the na Sayers that think it’s better to have their HTT jacked up in the air. You can compare and make your own decision.
My comment about the step really wasn't about ground clearance. My sisters Jayco and our Roo are about the same from floor to ground. Our Roo, however has 2 steps to enter the door whereas my sisters Jayco has only one, and it is a big step to climb in. The steps are bolt on and am sure a dealer could change them. I was merely pointing out the differences.
