power usage shouldn't be much of a concern since it's just a small computer fan. i don't see why there'd be additional heat needed... composting will work above 55. the toilet is in the heated cabin with you so if you keep your camper heated to 55 you should be fine, right? do lithium batteries need to be vented or can you store them inside with you?
