214skier's avatar
214skier
Crack. THUMP! Woosh~
Has this happen to anyone with a TC?
While finishing up a two day camping trip to Chelan Falls, Washington (yesterday), we heard a crack immediately followed by a loud thump and then water began to spill from the basement underneath our camper.
At the time we had been off loaded and on level ground. Our grey water tank was nearing full (not a huge surprise).
I opened the aft sewer door and could see the "inflow" pipe had separated from the top of the grey water tank. Whatever was in that pipe (and the little fluid immediately at the top of the tank) had poured into the basement and eventually finding its way out of the camper.
Unfortunately the grey-water tank is in front of the black water tank with no immediate access. You have a good view of the in-flow pipe (now clearly separated from the tank); however, it is hard to make many other diagnosis at this point. Maybe the tank is sitting askew???
Current theories: A) with the full tank, weight etc, the base supporting the tank somehow collapsed, dropping the unit a 1/2" (approximately), pulling away from the in-flow line.
or
B) When installing the in-flow line, gluing etc., the factory didn't realize they lifted the tank slightly off the base. Finally, the glue gave out, dropping the tank.**
**I see this theory as least likely, considering the unit is a 2007 and it has many miles of travel with at least a semi-full grey water tank.
I am hopeful I can get it into service soon; however, I have to imagine gaining access to that tank is going to be difficult (cut access point via basement -or- cut up galley floor).
:E
Not fun at the start of the season
2007 Adventurer FDS
