dhull
May 22, 2016Explorer II
CWR vs Payload
Trying to figure out exactly what the CWR (Cargo Weight Rating) numbers are for as shown on the label inside the glove box for trucks that are approved to carry a TC. I understand that payload is the diff between the GVWR and the actual weight of the truck (often called curb weight). I did think payload & CWR were the same thing but after comparing a few trucks that have both the glove box sticker showing the CWR and the door pillar sticker showing the payload I've noted the CWR is always considerably less, like 800 lbs or so.
After reading Ranger Tim's post on his maiden voyage I'm now thinking CWR is the difference in lbs between an unloaded rear axle and a loaded rear axle. Is this correct? That would explain the weight difference between the 2 stickers.
Should I think of it like payload is the max you can carry distributed on both axles (without going over each axles rating) and CWR is the max weight you can add to the unloaded rear axle weight?
I'm confused as my "Truck-Camper Loading Information" document from Chevy defines CWR as "the maximum weight of the load the vehicle can carry. It does not include the weight of the people inside. But use 150 lb for each person." To me that's the definition of payload! I'd think the weight of the passengers would end up mostly on front axle anyways.
