westend wrote:
If I was using a power supply in a typical travel trailer, I would connect the output of the supply to the two studs on the trailer's 12 V distribution panel. The typical 12V distribution panel has a number of fuses for the different 12V devices that are powered.
I guess you have no plans to move this trailer on the road? There are laws about break away emergency braking systems but if you live in the bush, they may not matter.
thanks that's a very good solution to keep the different DC circuits fuse protected
you're correct, i live in the boonies and have no plans to ever have the trailer on the road
here's what i have...where would i connect a stand alone power supply to keep the fuse protection, using the built in fuse panel
