rexlion
May 21, 2018Explorer
Keep in mind that the listed dry hitch weight is unrealistic. It does not include LP tanks, battery, or any options... let alone the cargo you put in the cupboards or the water in the tanks. I had a KZ E14RB and (best I can recall) the dry weight was about 280 lbs, but in real world use my hitch weight varied from 350 to almost 400 lbs depending on the water in the front-mounted fresh tank and hot water heater.
You might take a look at these Prolite trailers made in Quebec. Not sure if anything they have will suit you, but if so, they are very light in weight and in hitch weight. They have a handful of pre-owned units listed, too.
Another Canadian trailer worth mentioning is Taylor Coach since they are very light weight and have a good reputation along with a 4 year warranty. Best bet is a used one (maybe on Kijiji.ca), because they have a 2 year wait for new units!
