theoldwizard1
May 22, 2018Explorer II
SoundGuy wrote:
In the years Coachmen has been using Azdel the company AFAIK has never claimed it's used anywhere other than in the side walls of the trailer, not the front or back walls nor certainly not the roof or floor.
100% correct ! Got to read the fine print !!
I can understand why they don't use it in the front especially with a one piece fiberglass "nose", but why is the back wall wood frame and luan ? To me, that just smells like trying to "save a buck".
I would like to see the cost difference between tradition T&G 5/8"-3/4" plywood subfloor and 12mm-1/2" real marine plywood. You would probably need some additional bracing and without T&G, the seams might be an issue.
