KeithF40's avatar
KeithF40
Deep cycle battery for AC?
Hello everyone. New to the forums and RV world in general.
I have a 2016 Starcraft AR-ONE MAXX 19 BHLE. I plan on doing a good amount of dry camping but will be turning off the generator at night sometimes.
I want to get a deep cycle battery that is capable of running the AC overnight. I don't mind having to purchase two batteries and running them in parallel if that is what is necessary. Thank you.
  • A 12A A/C will draw about 130A from a 12V battery. 2 6v deep cycle batteries at 220Ah can supply 130A for 50 minutes to the 50% level. That works out to about 20 6V batteries for 8 hours and about 1,400 lbs.
    Run the gen all night.
    Or you can set up a 48V lithium battery set which will be less weight and can discharge to 20%. Then run the gen all day to recharge. And the cost will be $$$$$$$, if not more.
  • What @rjsurfer said.
    I came across a youtube video of a guy who set up to do that, but he was running a 5,000 btu, energy star AC, not the 13,500 btu unit on your camper. He did it with 600 watts of solar JUST FOR THE AC, 1100 watts to run everything else he wanted to run, and several Lithium Iron Phosphate batteries. Unless you downsize your AC, you are going to need a minimum of 2,000 watts of solar, and a dozen or so of those lithium batteries. Merely buying another flooded cell lead-acid deep cycle battery isn't going to do anything useful for you.
  • You're talking about a $6,000 plus investment in Lithium batteries, solar panels, inverter, solar charge controllers and a complicated mess of wiring to run an AC for just one night of cooling. And if the sun isn't shining the next day you better have a $2,000 generator to recharge your batteries.
    Ron W.
  • You wouldn't be able to carry enough batteries to handle the load.
