BurbMan's avatar
BurbMan
Explorer II
Nov 30, 2014
Defective Michelin Tires
Not strictly tow vehicle related but thought you tire gurus may be interested in this. I just put a set of Michelin’s new Premier all-season tires on DW's Magnum. These are the tires they are advertising that don’t lose their wet weather grip when they are worn. They actually mold the rain grooves like dovetail slots, so that as the tire wears the rain grooves get wider as they get shallower, so they still channel the same quantity of water away from the tread.
The guys at the local Tire Discounters have been great, I have been using them for all my alignment work, but this is the first time buying a set of tires there. Out the door including the free alignment the set was $920, plus a $70 rebate by mail for a net price of $850. Pricey, but ironically less expensive that Goodyear. Unfortunately not many brand choices in the size they put on the Hemi R/T Magnum, P225/60-18.
So I take the car in to buy the tires, they tell me the right inner tie rod is shot, and so the alignment is not exact. They agree to give me coupon for another free alignment, since I wasn’t having them do the repair work. I get it home, jack it up, and I was able to confirm that the right inner tie rod was in fact shot, so at least I feel good that they aren’t selling me bogus work.
I order a set of inner/outer tie rods from Rock Auto and put them on the following week (the way Chrysler designed the front end on the Magnum/Charger/300 LX chassis these things eat tie rods, but that’s another story…), go back and get the car re-aligned, and I’m thinking all is good. We take the car to Indy for Thanksgiving and it was like riding in a blender…the steering wheel was dead calm, but there was a bad vibration in the seat that started at about 65 mph and got progressively worse with speed.
Back to Tire Discounters on Friday, they tell me that the LR tire was not balanced correctly, they re-balanced it and said all was good. I took the car out on the bypass and all was not good, it was still a blender with a steering wheel. Thinking it’s not the tires I decide to start my diagnostics yesterday. I put the car on jack stands in the garage to check it out. The vibration was definitely coming from the back, so I am looking at wheel bearings, CV joints (car has a live rear axle), U joints, driveshaft carrier bearings, anything that might have some play in it. I decide to start the car and let it run in gear at idle on the jack stands while I observe the drivetrain in motion.
Once the car was running, I immediately found the problem…it was the tires. I recorded a video on my phone with a ruler taped to a 2x4 next to the tires as a reference scale. Here is the video on YouTube. The first few seconds are the left rear tire, note how bad the runout is, almost 1/8” both radially and laterally. When the scene shifts that’s the right tire, which wasn’t as bad radially but actually worse laterally. The last part is a square next to the left rim showing that the rim is true and not bent. I did the same on the right rim, but accidentally saved it as a separate video.
So now on my 4th trip to Tire Discounters, I show the manager the video and he agreed that the tires were defective. They replaced the rear two yesterday and now the ride is smooth again. I’ve never gotten a defective tire like this, let alone a Michelin. The manager said they had a another customer who bought these tires and then switched brands after complaining about a harsh ride, so he wondered if it may have been the same issue….hard to believe that the tire tech balanced the LR not once but twice and never noticed the runout. I’m having mixed feelings about this….while I am glad they resolved the issue without giving me an argument, they never should have installed those tires to begin with.
Anyway, thought you guys might be interested in case anyone is tire shopping.
  • My Town Car has a 2 year old set of Michelin tires on it with about 35k miles on them. The tread is like new and yet I am replacing them at the first of the year. The sidewalks are rotting off.... 4 sets of Michelins....4 sets with sidewall rot long before the tread wears out.
    Never mind that they are the WORSE handling four sets of tires I have ever had.
    Never ever again... Not buying any more of the hype.
    The brand that has treated me the best over the years has been, of all brands, Cooper tires
    Want to guess what's going in the Town Car? Yep a set of 60k Cooper tires.
    On edit... I did have another set of horrible riding and handling tires... BF Goodrich... Imagine my surprise when I found out who owned them.
    Thanks!
    Jeremiah
  • Several comments:
    Dots on tires: There is no standard way of doing this. Some tire manufacturers use the dots, some use something else, some don't mark at all. Further, there is no standard that wheels have to be measured and marked - and many wheel manufacturers don't use the valve hole as the mark.
    Then there is the issue of what the dots mean. It is common for the red marks to be used to indicate the tire's uniformity high point (think runout and you'll be close) and the yellow dots to mean the heavy spot of the tire (balance), but this is far from universal. The idea is to match the high point of the tire with the low point of the wheel to get a "rounder" assembly. This is NOT the same as minimizing the balance weights.
    Please note, it is possible to have a perfectly balanced, but out of round, tire and wheel assembly.
    And lastly, it is quite possible to have a tire not get fully seated on the wheel. For some reason, most tire mounters don't realize that a bit of lube on the beads AND the wheels helps the tire fully seat. Some runout issues can be traced to this.
  • My last set of Michelin tires on my Chevy TV was probably my last... I had them on for 19 months and 25k miles and they were nearly bald....rotated at every oil change (5k). Michelin was going to pro rate them for a new set, but still quite costly. I ended up changing to Nitto tires. They were pretty good tires for the time I had them, before trading in my truck. This was about 3 months ago.
    Cale
  • No argument here...when I had the LTX/MS on the burb many years ago, I had similar issues as you all describe...sidewall checking, poor handling, etc. Michelins on the Magnum have been excellent and exactly the opposite...no sidewall cracking at all, great ride and handling, and got 60K out of the last set over 4 years. Always ran Pilot Sport A/S on the SHO and also had very good results with Michelin. We will see how these do....
    Did not know that, thanks.
  • tsetsaf wrote:
    $900 for car tires!?
    Some people will pay whatever Michelin wants because those tires are supposed to be "The Holy Grail" of car tires. Of course, with recent longevity issues, and dry rot issues there seems to be a crack in that theory.
    Here's my Michelin Holy Grail tire. I had 9 or more year ago. Just blew up in my driveway.
  • BurbMan wrote:
    The warranty form going back to Michelin has the DOT serial numbers of the tires, so I'm sure they will go back and look up lot, batch, etc. They are 4614 dates codes and made in USA.
    ^^^ This.
    There is a feedback loop for this sort of thing. You should have had them replaced by the shop and glad you did.
    As mentioned previously, runout can be from problematic mounting as well, but instead of subjecting you to back and forth with that, a new replacement was the right move.
    You can also have "balance" and still have runout.
    No company is what it once was. Everything is subject to a bureaucracy these days ... the best customer service is from smaller owner-run companies who keep their ear to the ground.
  • FastMopar, I grabbed a quick pic in the garage last night just for you
  • Oh, very nice. I like the color and the look of the stock rims. Very nice. Thanks. I'm sure it sounds great, too.
  • LOL not really....It's got an exhaust leak somewhere up front, not sure if it's he manifold or what...that's next on the honey-do list! DW likes "Cynthia" to run smooth and quiet!
