Lowsuv
Oct 22, 2014Explorer
SprinklerMan wrote:Bird Freak wrote:
I'm just curious here and not trying to start a China tire war. Where did this age old wisdom of a tire must be replaced after 5 years come from? Was it a tire manufacturer or just some people decided you should buy new ones? There are a bunch of tires out there that run a lot more years than that. Where was something credible in print?
I own 6 tandem axle trailers and 2 single axle trailers ( including my TT), with spares thats 36 tires . Am I replacing them every 5 years , no way , thats why I run LT tires on the heavy tandems that see highway miles , on the local light weight ( dont carry anywhere their capacity ) I run passenger tires . The trailers that go to the landfill get the ST tires . ( they are the sacrifical tires). I replace tires when they are either worn out or are showing a problem .
Sprinklerman knows his stuff because he has to .
There are way too many folks on here praising their brand new Maxxis tires from Chang-Shin Rubber of Taiwan .
These guys are slapping each other on the back yet they fail to understand that the single best thing to do at replacement time is to make an actual upgrade to LT rated tires .
There are frequent posts about ST tire failures but next to none about LT tire failures .
About one/two maxxis / Chang-Shin failure reported per month for the last couple of years .
Thanks to Sprinklerman for some common sense gained by experience .
LT tires prevent failure when you need it most : on vacation !
