JIMNLIN
Oct 23, 2014Explorer III
I do know it's a 16" BF Goodrich, but I don't know the exact size.
I'm assuming also these go to 80PSI for that max load, so inflation will be important to hold down any bounce from running too "hard". The axles also have shocks, which should help alot I imagine.
There are recalls on the BFG Commercial T/A in the LT235/85-16 E and LT245/75-16 E http://www.bfgoodrichtires.com/voluntary-safety-recall.page.
If those BFG tires you mention are the Commercial TA make sure their the new BFG Commercial T/A "2" all seasons which is the latest upgraded tires from BFG.
I use the BFG Commercial in a LT215/85-16 E at 2680 lbs capacity on my 11200 lb 5er/5200 lb axles. Great tires. I have 45k + miles on the second set. The first set ran 7 years and 55k miles with no issues.
Also the LT225/75-16 E are shorter if you need the room and has 2680 lbs capo
acity.
