Retired_nuke_ET
May 24, 2008Explorer
8.1 Van wrote:Full Pull wrote:
with light mods you can add additional 100 hp and 180pft at rear tires...
and get more mpg.
BS, you can't get 100HP more by using less fuel. Do you think when an engine is on a dino there is less fuel going into it as the rpm and power goes up ? :R
See you made the assumption both occurred at the same time. It is possible for a chip to add 100HP at WOT and modify the timing at lesser power levels to increase the MPG over normal everyday driving conditions. Sure if you have the chip cranked up to level 9 and your foot into it all the time, you'll have more power and your mileage will suck. I believe the OP meant you can set the chip to level 1 or 2 and enjoy better MPG then crank it to 11 when you need just a little more to push it over the edge than 10 can provide. But then that's just my assumption.:)
44,054 PostsLatest Activity: Dec 18, 2025
