transamz9
Aug 10, 2012Explorer
I'm not trying to be a pain in the *** but I am like you trying to get as much of the info on this thread correct. First off Taco I'm sorry, I didn't catch the "I" in the post where you said that it would cost "you" 14-15G more. I'm sorry for that. So you bought a half ton instead of a three quarter?
As far as routine maintenance cost go, yes if you buy a Ford diesel because they have to until they get the bugs worked out. The others, I don't think so.
OhhWell, I know that torque is stationary but here's my theory. You guys have already said that a diesel will get up to speed quicker with a load because of the low end torque. If you think about it , it makes sense if you have 600 lb/ft of pressure trying to turn a wheel as apposed 300 lb/ft of pressure trying to turn a wheel. Same as true if you are already running a set speed (flat ground) and you start up a 6% grade. It's going to be harder to slow a wheel's speed down that has 600 lb/ft then it will 300 lb/ft.
Am I thinking correctly?
