azwildcat99
Aug 13, 2012Explorer
wnjj wrote:
Its torque determines the gearing you need to keep the engine in its sweet spot at speed. Its HP determines how much of a load you can move at that speed.
I have been reading the posts for a while, but finally decided to chime in after everyone's reluctance to acknowledge the fact that...
Horsepower and Torque are related!
http://www.1728.org/mtrtrq.htm
HP = Torque * RPM/5252 So unless you are revving your engine up above 5200RPMS or racing F1 at 19k RPMS, HP is largely irrelevant. It's the torque that matters. Diesel or Gas your TV makes more torque than HP at the engine speeds we are pulling at, any of us. Given that, a diesel usually has superior figures (500+ vs 300-400).
As to the Diesel vs Gas, if you can afford it go Diesel, but there is nothing wrong with Gas. Cheaper fuel, less smelly, lower maintenance costs, easier to work on, and the list goes on. But Diesel has it's share of pros as well. I don't think there would be much of a debate if the up-front costs were identical.
I used to tow our 3k pop-up for years with my 5.3L 4sp 1500 with 3.73. It towed great, but downshifted to 2nd on the 6% grades. I then moved up to a 7000lb 31ft TT and it was having to downshift to 2nd on the freeway (just the 101 not I-17 here in AZ). I recently upgraded to a 07 Classic 2500 D/A. What a difference! It stays in 4th gear up the grades to Flag and can accelerate if I choose, but I say around 60 for sanity :-)
Good Discussions!
