OhhWell
Aug 23, 2012Explorer
Madhatter1 wrote:Hannibal wrote:
You need to put it into perspective. A 350 hp tractor engine running at it's peak hp rpm of 1800~ is at it's peak hp rpm. A 350 hp SB gas V8 in a pickup truck running 1800 rpm is almost 4k rpm under it's peak hp rpm and is likely making less than 120 hp.
If you think those 350HP enines are equal for moving a big load you are way off. The tractor is over 1000 lbs torque at 1800 and the gas is at 300 lbs at 4K (using your example numbers). Another BIG factor is the tractor is makeing big HP numbers at lower RPM's and the peak torque is going to be much higher than 1K. You guys are doing a dis-service to posters looking for info on gas vs Diesel. Even if us Diesel guys post they are not as fuel efficient, as reliable, or as cost effective as they used to be the gas fans still neeed to say "mine can pull the same load through gearing". Might be able to do the job (which is an inportant fact for those that need a truck more for a daily driver than towing) but a low RPM Diesel has a big advantage pulling a load. Get off your high horse and talk facts to help out posters looking for some real world info. I drive a 4X4 3500 Dually Diesel but can recognize that is not what everyone else needs. I pull a 14.5K to 15K trailer all over. Off road a lot. Still not gonna tell someone who pulls the same load 100 miles to a paved campground they need the rig I went with. And you "engineer math guys" need to drive a truck with a load on it. Your calc's do not work out in the real world. If they did a pair of 260HP 350CI gas engines could equal the 260HP Cummins 360CI in my boat. They would never be expected by any marine designer to even get the boat to plane off. What??? I thought HP was HP. 350 HP at 1800 RPM in a whole different animal than 350HP at 4K or 5K. Flame away.
Opps, sorry. Missed that part. Despite bringing a boat to a truck fight, I will address this. A high torque engine in a boat amkes a much better direct drive powerplant than a low torque engine obviously. That's why gas inboard engines often have transmisions. No way a low torque gas engine is going to turn a large prop easily at low RPM. That's what a high torque rating is for.
Big heavy boats and big heavy trucks are well served by high torque slow turning diesel engines. If you want speed, that's more the realm of gas and horsepower, especially in boats.
