rhagfo
Nov 04, 2012Explorer III
Taco wrote:jevanb wrote:
folishly??? I bet you 10 bucks I spend less for my 06 brand new then you paid for you 2012 and I also pull in the mountains of kentucky, wva, va,tenn, and planning to going to montana and then down to phoenix thru the rockies with our 13k 5er, lets see your 6.0 do that, it prob would but I would not want to do it and I also towed my entire house hold goods in 05 from MD to MI and the hills on 70 killed that truck with 7-8k behind it. I made that trip 6 times with that trailer loaded and hated it everytime plus getting 9mpg sucked
You may have spent less for your 06 but I have a truck that is 6 years newer. and in 06 I could have bought a 6.0 gas for less than your truck. I don't really see how it applies. Foolishly speaks to the fact that you got rid of a perfectly good truck which I'm sure you took a loss on to spend a rather large upcharge for another truck. The gm 6.0 will tow 13k if you need it to. Might get a little slow in higher elevations where the diesels turbocharged engine really shines but it will do the job.
Yes 8 mpg sucks but the diesel will never pay for itself in my use in lower fuel costs. The price you pay for the diesel engine will buy lots of fuel. My truck will pull any interstate grade you will find short of the high elevation ones in the rockies at 62 mph at 3800 rpm so at about 60% of redline. I wouldn't call this killing the truck by any means. 20 years ago you could buy a truck with a 3 speed auto and a 4.56 rear and you would turn those kind of rpm for hours straight to go 65 down the interstate. People back then just weren't so scared of rpm.
Taco, will your 6.0 pull 14K as well as it pulls 8K??
You might look at what Jevanb is pulling with his Dmax!
Sorry that 6.0 gasser is fine for lighter loads, but doesn't have the torque to move the big loads.
Yes the cost savings take a while to make up, unless it is a Daily Driver.
In addition 8 mpg as opposed to 12 mpg (not stated, but about right) means that Jevanb is getting 50% better fuel mileage and likely only speeding 10% more than regular gas.
Driven both with the same trailer, 460 (7.5 liter) F250, and 5.9 (359 ci.) Cummins 460 had 148K miles, the Cummins had 234K miles 100 ci less engine and the difference of night and day, the Cummins had no issue holding speed on hills.
