brholt
Jan 09, 2013Explorer II
rhagfo wrote:davisenvy wrote:spud57 wrote:64thunderbolt wrote:
I will still extend my invitation for anyone with a gasser & similar wgt trailer to come tow with me in the mtns in Az. When finished we can compare towing speed/rpm and fuel milage. The gasser will fail in all catagories.
For it to be fair it has to be stock vs. stock. My stock 6.8 gasser 362hp/457tq and your stock 7.3 diesel 235hp/500tq. Yep, you'll burn a bit less fuel but I'd be curious who'd be at the top first. RPM comparing is irrelevant. Let both engines do what they were designed to do without all the "aftermarket" add-ons.
I'm not suggesting that I would beat the 7.3 stock because I don't know. :)
"For it to be fair" compare apples to apples. Your truck is 9 years newer. Compare the 1999 Triton V10 with 275hp/410tq vs. the Powerstroke 235hp/500tq. Or in 2008 V10 362/457 vs the diesel 350/650. Either way, you lose the race....stock vs. stock.
With your argument I should be challenging a 1998 V10 275/410 vs my Duramax LBZ 350/650. So to prove your point you should be running against jevanb.....or me if you like. A run without "add ons" and one with. You can bring your add ons too.;)
Dang you two, just accept that year for year a Diesel will out tow a gasser!
I would put each of the big threes, diesels up against their gas engines, no match!
Well, pickuptruck.com did that in their 2010 shootout. On the 16% hill climb pulling a 10,000 lb trailer the times to the top were:
25.6 Chevy diesel (32 mph @ top)
26.74 Ford diesel (@ 31.1 mph)
30.75 Ford gas (@29.5 mph)
30.95 Ram Diesel (@24.2 mph)
35.6 Chevy Gas (@24.9 mph)
36.4 Ram Gas (@22.1 mph)
So one gas beat a diesel up the hill and two gas engines were going faster then one of the diesels. Off course it is going to depend on axel ratio's etc. but modern gas engines can be pretty competent.
