transamz9
Feb 27, 2013Explorer
Hannibal wrote:transamz9 wrote:There's a little more to changing diesel injectors than righty tighty, lefty loosie. Anyone who really does do their own work would know this.
No, really there is not. You unbolt what you need to get to them and you bolt back on what you take off, it's that simple. I do all my own work and then some. As far as the electric connections go, they will only plug back the same way.
So really there is not yet really there is.:S
What does this simple task take, 20-30 minutes?:h
The last time I looked under the hood of a Dmax or PSD, there was plenty to remove just to get to the injectors.
Really? This is silly. That's like saying that someone would have to pay someone to mow their yard because the have 3 acres to mow instead of a half acre. If you can remove 1 part you can remove a thousand bolts. The D-max that I did was the first one I have ever done and it took me right at 12 hours. That was taking my time and listening to a ball game and doing some stuff on and off for the DW. The biggest problem people have is they raise the hood and become overwhelmed at what they see. The air filter box on a '03 duramax is literally held in the truck with one (1) hose clamp.
I'm not saying people should tackle pulling the motor. I'm just stating that people could do more than they thing if they just tried a little bit. The PS 6.0 injector job is actually easier just mor stuff to take off.
Passenger side injectors on an 2003 duramax done and getting ready to start putting back together. Things that were removed: air filter box and tube, air tube to the inner cooler, fuel filter housing, FICM (fuel injection control module) 4 high pressure fuel lines, two piece valve cover.
