rcpd34
Mar 25, 2014Explorer
How exactly can you haul more than any gas engine? Your GVWR doesn't exactly say so or the DOT laws. Nor does the fact that you can get a gas silverado with the same axle, springs and tires, and less curb weight. Doesn't make a whole lot of sense.
I have seen plenty of fuel stations that don't carry diesel. Many more only have one pump that isn't a dedicated diesel pump but shares it's spot with a gas pump that may be in use by a gas vehicle. I can bet that more often than once a diesel owner has had to wait for a vehicle to be moved from the one available pump.
Funny that you felt the need to pay extra to hedge against the possibility for a very high dollar repair on your diesel engine.
You may not live in a climate that is cold enough to need a block heater and diesels have gotten better but for some climates it is still a concern.
I'm glad you're happy to have to buy more oil???
My point is my diesel has the power to haul any load better; quicker, safer and more economically than it's gas counterpart. I'm not a commercial vehicle so I'm not worried about the weight police. When you order a Diesel (and big block before it was discontinued) you got the Allison and a heavier duty rear axle. It is not the same as when you egt a 6.0. Never had a problem finding diesel and everyone at some point has had to wait for fuel. To suggest otherwise is just silly. Where I live we het down to the low single digits; never had a starting issue; never plugged in. Don't be a hater.
44,071 PostsLatest Activity: Aug 09, 2026
